BSNL Broadband Billing Problems
  • Thread starter Thread starter pupudada
  • Replies Replies 131
  • Views Views 86,656
@adi24 Usage check Portal almost normal. Day usage and night usage shown separately.
BSNL - Broadband Account Management
This site gives usage details of previous months also. ADD to BOOK MARKS>
This is the site where you enter 14digit password and password as password. ( if you have not changed it ).
http://i31.tinypic.com/34do39z.jpg
Take a print out /save to disk/ screenshot of unbilled Day usageand night usage. for records , if needed. If you have the receipt for change of plan to Home500/(paid extra security anount?) and exchange also says so,. no problem.
Para two : for your @ bsnl .in email go here. ID user ID and P/w old given for connection.
Dataone WebMail . or directly here Login ADD to BOOK MARKS
when i go to the site where we can check the usage there is one link my orders !
when i click there it shows my plan starter 250 but my plan is 500 and the BSNL exchange ppl are saying that my plan is 500 only!
there are two sites to check the usage
pls give me the link of the site from which u or most of the new users check the usage
same thing happened to me too friend!in my case one officer mistakenly forwarded my plan as 250 instead of 500 to banglore & in my case too all exchange records said that i got home 500 but my bill came according to 250.i have good contacts at local exchange & senior most official was very friendly with me as my father is a senior govt. official too.so my bill got corrected without any major problem.(DE himself,the 2nd most senior official of bsnl in a district after DGM,sat for full 60 min while i calculated my day usage & night usage using calculator & made the bill according to that).
so immediately contact your local exchange & most probably someone has forwarded your plan details incorrectly as home 250.i don't know how much trouble you have to go through before correcting your bill but in my case if same thing happened to some one else not so well connected i believe the matter would be settled in court unless some more senior official intervened at circle level(above district level).
@essbebehey frnd thanks for the cooperation but arre still it is not showing the bifurcation between the night and day use !!!:(:(:(:wall:thanx!!!!!!!!!!!
Please see Post No 57. ( nothing new to say )Hope your usage data also will be shown day/night separately soon.Now the other usage meters, like DataFox, DQUF, Shaplus etc will be modified soon, I hope.
does any one know the email address of customer care ie broadband customer care :(
Today in Bangalore, I got a bill of Rs 25989 for my UL900+ plan new connection. The online portal shows that the plan is Starter 250 which is wrong. Just noticed that this is quite low compared to some of the earlier records posted in this forum. Time for me to visit some BSNL offices. Wish me good luck.
the site for checking the usage of the new connections is not opening is there any alternate site to see that usage ?
For BSNL users with IP 117.xx.xx.xx and ID @ bsnl.in
001.
log with 14 digit portal ID and password password
002
BSNL Portal
login with 14digit portal ID.
003:
UPDATE 24th May 2009:
Web Registration for Usage Alerts
will alert you only when
exceeding the usage limit ( Hopefully !)
003A: For Hyderabad users Seperate usage portal.
Should register in Selfcare. web site.
004: (update 24th Sept 2009)
If you have your consumer number ( see telphone Bill )
try this short cut to see Summary Usage
Enter your consumer number for "12345678"
(a) old usage months
UsageReport.jsp
h t t p://www.data.bsnl.in/wps/PA_SfCareUsageDetails/UsageRecords?accNo=12345678&UsgMnth=Nov-2009-Billed&serviceuserid=null]UsageReport.jsp[/url]
(b) new usage unbilled.
h t t p://www.data.bsnl.in/wps/PA_SfCareUsageDetails/UsageRecords?accNo=12345678&UsgMnth=Dec-2009-Unbilled&serviceuserid=null]UsageReport.jsp
UsageReport.jsp
Copy/Paste above and change "12345678" with your consumer number.
************************************************************BW meters
005:
Dataone Quick Usage Finder Beta Download | sunish.net FREE
Or
006:
( link-removed)
link-removed.com/files/114469048/DQUFSetup_0.7.0.0.zip
007:
Datafox add on if you are using FireFox browser.
DataFox - A BSNL DataOne & MTNL TriBand bandwidth usage monitor FREE
Latest version 1.7.5
or
008:
UPDATE AUG 12TH 2008:
How to find Monthly Dataone bandwidth usage
009:http://shaplus.com/exes/misc/DataOne-Bandwidth 2.8.1.zip for Ip 59.xx.xx.xx137KB
010http://shaplus.com/exes/misc/BSNL Broadband Usage 1.2.zip
for ip 117.xx.xx.xx 135KB
http://www.shaplus.com/exes/misc/ShaPlus Bandwidth Meter-Setup.exe
011:
Tautology Bandwidth Meter - Internet Traffic Usage Monitor with timer) FREE
012:
Image - TinyPic - Share the Experience!™
For uploading images etc. Added advantage
Enter Dataone in Search Box for my old screen shots.
013:
dataone Ip 59.xx.xx.xx same userID and PW
For ref : http://10.240.0.195/webLogin.jsp
014:
May be out of date now.
http://duf.sourceforge.net/ DUF version 2.0 updated july 2007 FREE
015:
NET METER 1.1.4 BETA
25th Sept 2009 FREE
==- Readerror -== - Downloads
016:
left blank.
017:
DU Meter - Free software downloads and reviews - CNET Download.com 30 day free trial.
018:
UPDATE 28TH JULY @socrates Watchwan free.
WatchWAN - Free software downloads and reviews - CNET Download.com
019:
UPdate:13th Aug 2008.
Windows task manager processes, Windows startup, Startup programs, Vista tweaks | Task, Ma
Anvir Task Manager. Shows daily usage in TaskBar.
020:
UPDATE Sept 19th 2008.
OpenDNS
@cool_techie_tvm @whitestar
020:
update 24th nov 2008.
DeskSoft - Old Versions
new version not downloading.
Part Two;
WEB mail:
for IP 59.xx.xx.xx same userID and PW.
OpenDNS WEBmail : Dataone WebMail
Login
For IP 117.xx.xx.xx abcd @bsnl.in
Obtain a different UserID and Password. ( three sets totally )
Login
SMTP : not same as for dataone. smtp.bsnl.in
POP3: ............do.............. pop.bsnl.in
Update Sept 6th 2009.
pop.bsnl.in and smtp.bsnl.in
OUTLOOK EXPRESS CONFIGURATION
Part three:
030 "Sticky" POST
Most modems/routers wifi settings 3500 hits till 15th Dec 2009
041:
Port Forwarding :.
Reviewed November 7th 2009/15/12/2009
