BSNL Broadband Combo Broadband Plan 99
  • Replies Replies 62
  • Views Views 8,293
i am a existing user and got modified to 99rs 45gb plan through selfcare portal ,but speed remains same as old plan 545 plan 8mbps,today is the first day ,dint get 20mbps,also not sure of there security deposit and speed in coming bills and days,have anyone tried the same as me ?
i havnt got the downstream updated yet,its still the 7996 according to old plan speed,may be i should write in grievance about upgrading my line rate ,last time i did the same as the officials in local dint have enough knowledge.will do it on monday i geuss..by the way do you know for how much days or months this plan is valid till it will be changed automatically(i guess ) to the lowest plan,after this i am planning for 249 plan anyway ,heard by the customer service guys that a written application form must be given to modify the bb plan to 249bb ...
just tried to change bb plan in selfcare bsnl...it was available and i dont care about speeds much just want a unlimited in continous speeds ...so just wanted to try this..even when i am a existing user ,infact this is only for new users...by the way i got to know in copper wires the high speed isnt possible in other posts ..anyway i am still getting 6.7mbps with 99 plan changed...just hope the bills go down
i am going to change 491 plan but they say you only get 6mbps in your area maximum 8 mbps for copper wire is possible.
i took a new 99 plan broadband connection.
Applied online, submitted docs via email and the connection was given all within a week. Didnt have to visit any office or chase anyone to get the job done. This is pretty impressive stuff from BSNL. However the happy browsing offer doesn't seem to be applicable for this plan. Speed drops to 1mbps after exhausting 1.5 GB data.
Line stats attached:
SNR Down stream : 25.9
SNR Up stream : 22.0
Attenuation Down stream : 16
Attenuation Up stream :9
Attainable rate Down stream : 26388 kbps
Attainable rate Up stream : 1304 kbps
Rate Down stream: 12495 kbps
Rate up stream : 621 kbps
Line is locked at 12.5 mbps even though it has capacity for 26 mbps. However browsing at 1 mpbs post FUP is really slow so considering changing plans to higher FUP quota.
yes sandgoldline,i too get 6.7mbps through ethernet and 5.5 with usb to modem,thanks for the info antony,were you a new customer or existing??i am a existing user just tried this 99 as i am paying 812 0r 808 rs per month too high for 545 plan,my speed dint change but today i filed a grievance about the speed to change the line rate to highest possible,well yes i too will get to 491 after this 99 gets its time over...even if i get 10mbps in 99 plan for some days i will be excited :))
