Just to make sure its a line problem please check and post your downstream and upstream sync rate from your router's setting page.
[COLOR=\"Silver\"]-------------[/COLOR]
The best way to get all these things sorted is to write a mail to MTNL directly. Search on this forum for the list of email IDs of MTNL to which you can lodge a complaint.
Zeo,
After sending an email and telephoning the number they responded with, the speed has improved. These are the rates now :
Downstream Upstream
SNR Margin 36.2 13.8 db
Line attenuation 11 10.2 db
Data Rate 2048 509 kbps
MTNL's speed test now shows a download rate of 1.790 Mbps. SPeedtest.net gives this result :
https://www.speedtest.net
Thanks a lot for your advice.
Zeo,
Downstream Upstream
