Hi.
I am in S Delhi, and having DSL-502T modem.
Been facing a first-time problem since last saturday. Whats happening is this:
When i power on the modem, the Power light and USB light come on ok, then Status light and ADSL light blink for 4-5 seconds as connection is getting established, but then both go off together, and no net. Its the first time that Status light (one that continuously blinks)too is going off, earlier only the ADSL light was absent when line status wasnt good.
Since ydy, the net is connecting (after many many reboots) and then it works well, but the problem is recurring, needs 14-15 reboots before working. Have contacted 1504 and then my local broadband office, but yet to get a visit after 3 days.. Will harangue them today!
Anyone can tell about possible reasons for this problem? If the line is bad, can it be possible that net connects well when it does? Or more likely a problem with the router?
My line figures right now are:
Line State Connected Modulation Multi-mode Annex Mode ANNEX_A Max Tx Power -38 dBm/Hz Item Downstream Upstream Unit
SNR Margin 25 12 dB
Line Attenuation 23 14 dB
Data Rate 2013 260 kbps
SNR Margin 25 12 dB
