Thx for advice WiZZ .. Will do that .. however is there anyway to check the data usage ... I remember when I was on BSNL .. i could check my usage by logging on to their customer interface..
they sure are .. i asked them how do i know if I have crossed the FUP limit .. he said sir you will get a pop up on your system .. bloody idiot.
Airtel cc is persisting me to go for 1399 impatience plan.Right now im paying 1200Rs(1Mbps used to be 100gb fup reduced to 25gb),but cc says now mine has a 15gb fup then speed is 256kbps.SO what should i do?
