Excitel Broadband: 50mbps for Rs. 800, 75mbps for Rs. 970 & 100mbps for Rs. 1145
try using their own dns servers. sometimes their servers go beserk and third party dns servers stop working. usually fixes in a matter of minutes. sometimes an hour.
post some links that are not working. i would check at my end.
it went down here just 2 minutes ago. of course there is little i can do but wait.
takes too much effort to take out the ethernet cable and connect it to pc. i would just wait for it to come back like i usually do.
just connected now. probably an issue with local gateway.
Lodged a complaint and the reply is epic
Restart router for increased internet speed, lol
again lodged the complaint and now they're working on it
it's excitel problem for sure
working fine with VPN and other networks
asked my LCO to change the provider he said he will switch to fibre then all problem will be gone
is it true ?
fiber of course has higher capacity of data transfer than ethernet which is what they have been using for local networks in most areas.
