mgcarley
Founder, Hayai Broadband
What if some1 finds a way to HACK HAYAI's speed, HACK 4 the LIMIT set by HAYAI like 200 GB etc and posts in forums.
So what will HAYAI do in this case????
Historically this has been a problem with older style cable modems, but I think it's not really possible with newer systems, and as ACC1444 says below, our rate-limiting is only done server side, once the traffic is leaving the network.
Since we don't set limits, I don't see how anyone would hack them - the only flaw in the system would be if someone hacked the billing system - but in that case, that would be the billing providers fault, not ours, so anything that was "stolen" would have to be paid by the insurance of the billing provider.
Sorry to answer even though I am not a part of hayai.
This could not be happen unless there is a fault from server side. Normally, company buys professional software like airtel & tikona whose security systems are designed by inventum. So, these types of security systems test their software at last level of hacking and even their softwares are designed such that no one can do anything without log into the software.
I do not know about hayai but it may be hacked if hayai is designed by own self and not tested very well.
Ours is built in to our core routing platform, which requires a secure certificate to log in to.
Actually, in the past, this type of hacking problem is not happened with any company. Server fault or server downtime is another matter in this case.
You will get better answer from mg.
It can also happen when the load balancers fail.
It is ok if you do not know the distance. Actually I am asking because cable installation is never done in my area before. After launching hayai, I am guessing that I should get connectivity through wireless if I want to take. Tata was installed a cable before but due to local cable operator was not agree with them. They cut tata cable and Airtel is not deployed here yet. There is no chance of getting fiber connectivity for me unless you get the permission.
We can only but talk with the cable operator, or otherwise take measures to ensure he doesn't cut the cables, including but not limited to political or financial pressure.
About wimax, I am using wimax connectivity right now from local company, spidigo but I am facing some breaking with their connectivity & they have no solution of that because it works on free channels. Therefore, I was asking about to get solution which you may use in your system. With the experience, I realized that it can be solved by using high power device at both ends.
Let me know whenever you get the information about this.
Will do, but it's probably nothing to do with free channels or not - you state in the next paragraph that you're taking from companies even though they say it's not feasible. This is probably why your connection is so bad.
Yes, you are right. Company wants to be strict about feasibility regading their connectivity to avoid problems but as per my experience with existing company, I have taken connection from three different companies even though it was no feasibility. After installing it at my home, I faced lots of problem. So, I companied a lot to companies authority. Then, it comes out that sales persons gave connection to complete their targets even though requests were rejected by technical team. Sales persons never care about companies' reputation. They keep money in the targets.
That's probably half the problem. Perhaps some kind of directional wireless (maybe Free-Space-Optics) would be a solution for your area. It has a range of about 4km, but due to the air in India I'd probably halve that to be safe. We can push up to 1Gbit/s on FSO - but it's a little expensive to deploy so we'd probably have to share that among a few users.
