What if some1 finds a way to HACK HAYAI's speed, HACK 4 the LIMIT set by HAYAI like 200 GB etc and posts in forums.
So what will HAYAI do in this case????
Sorry to answer even though I am not a part of hayai.
This could not be happen unless there is a fault from server side. Normally, company buys professional software like airtel & tikona whose security systems are designed by
inventum. So, these types of security systems test their software at last level of hacking and even their softwares are designed such that no one can do anything without log into the software.
I do not know about hayai but it may be hacked if hayai is designed by own self and not tested very well.
Actually, in the past, this type of hacking problem is not happened with any company. Server fault or server downtime is another matter in this case.
You will get better answer from mg.
---------- Post added at 06:53 PM ---------- Previous post was at 06:45 PM ----------
There are legal limits to the amount of output the BTS is allowed to have, but we should be on different frequencies altogether. This is something for the technical guys anyway. I can tell you anything about the fiber network because I practically designed the thing (well, I speced it out and the actual designing was done by someone else) but when it comes to wireless I'm not as clued in - while I spec'd what it should be able to do, for the most part it was more of an acquisition than something we started building from scratch.
It is ok if you do not know the distance. Actually I am asking because cable installation is never done in my area before. After launching hayai, I am guessing that I should get connectivity through wireless if I want to take.
Tata was installed a cable before but due to local cable operator was not agree with them. They cut tata cable and Airtel is not deployed here yet. There is no chance of getting fiber connectivity for me unless you get the permission.
About wimax, I am using wimax connectivity right now from local company, spidigo but I am facing some breaking with their connectivity & they have no solution of that because it works on free channels. Therefore, I was asking about to get solution which you may use in your system. With the experience, I realized that it can be solved by using high power device at both ends.
Let me know whenever you get the information about this.
Thanks mg.
---------- Post added at 07:03 PM ---------- Previous post was at 06:53 PM ----------
We're not committing speeds at all - we have standards as to how the connection should perform and if the jitter/ping is too high and the sustained transfer rate is too low, we won't allow the connection to that area until we install a BTS there.
Yes, you are right. Company wants to be strict about feasibility regading their connectivity to avoid problems but as per my experience with existing company, I have taken connection from three different companies even though it was no feasibility. After installing it at my home, I faced lots of problem. So, I companied a lot to companies authority. Then, it comes out that sales persons gave connection to complete their targets even though requests were rejected by technical team. Sales persons never care about companies' reputation. They keep money in the targets.
