Hathway Broadband launches Docsis 3.0 Ultra High speed network
  • Thread starter Thread starter gopichandpai
  • Replies Replies 312
  • Views Views 105,681
akshay200x said:
Hi,
I already have a Hathway 15Mbps plan at home linked to TP-Link TL-WR740N 150 Mbps. I want to know if this same router will give me near 50Mbps speeds if I move to Docsis 3.0. TIA
Its a b/g/n router. If you have a laptop/desktop which can receive the N signal, yes, you should be able to reach atleast 47/48 mbps if not for 50 mbps.
Paid upgrade charges of 562+advance three month rental yesterday and Hathway technician installed the modem today evening. The login page is now gone.
jills4824 said:
Hey can anybody help me on this .. I am planning to buy this WiFi router TP-Link MR3420 (Product link) for use with Docsis 3.0 .. If anybody can check & let me know if it will work with Docsis 3.0 ? (Usage will be connecting Laptop & Phone).
Good stuff Jills.. Like the functionality of 3g, 4g and modem router. Yes, this will work with Docsis 3 network.
jills4824 said:
Thanks Alpha .. I hope I get the speeds that people are referring to here.
If you use the lan cable directly, yes, you will get the proposed speed. With WiFi, only if you use the N band you will 98% of the speed
Guys I called Hathway for new connection. But didnt have the chance to check the ping of gaming server. Can anyone please check that for me ?
1. ping for login.worldoftanks.asia
2. traceroute for login.worldoftanks.asia
Btw I am from Bangalore and opting for 50mbps 75gb postpaid plan.
I would be grateful to whoever posts the information.
Thanks
Aditya
Thanks
Aditya
Here you go ...
C:UsersMom>ping login.worldoftanks.asia Pinging login.worldoftanks.asia [92.223.16.47] with 32 bytes of data: Reply from 92.223.16.47: bytes=32 time=191ms TTL=53
Reply from 92.223.16.47: bytes=32 time=194ms TTL=53
Reply from 92.223.16.47: bytes=32 time=186ms TTL=53
Reply from 92.223.16.47: bytes=32 time=186ms TTL=53 Ping statistics for 92.223.16.47:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 186ms, Maximum = 194ms, Average = 189ms
Traceroute :
C:UsersMom>tracert login.worldoftanks.asia Tracing route to login.worldoftanks.asia [92.223.16.37] over a maximum of 30 hops: 1 1 ms 1 ms 1 ms 192.168.1.1
2 10 ms 13 ms 9 ms 10.133.0.1
3 10 ms 12 ms 12 ms 202.88.156.1
4 8 ms 9 ms 9 ms 202.88.156.66
5 9 ms 11 ms 10 ms 202.88.156.61
6 12 ms 9 ms 9 ms 202.88.156.254
7 8 ms 10 ms 10 ms 202.88.156.253
8 87 ms 33 ms 34 ms 121.241.129.122
9 36 ms 33 ms 34 ms 172.31.16.173
10 69 ms 73 ms 73 ms ix-0-100.tcore2.MLV-Mumbai.as6453.net [180.87.39.25]
11 172 ms 233 ms 170 ms if-2-2.tcore1.MLV-Mumbai.as6453.net [180.87.38.1]
12 176 ms 185 ms 175 ms if-9-5.tcore1.WYN-Marseille.as6453.net [80.231.217.17] 13 172 ms 175 ms 179 ms if-8-1600.tcore1.PYE-Paris.as6453.net [80.231.217.6] 14 137 ms 138 ms 139 ms 80.231.154.86
15 148 ms 137 ms 141 ms prs-bb1-link.telia.net [213.155.131.0]
16 384 ms 381 ms 383 ms snge-b1-link.telia.net [80.91.247.65]
17 183 ms 260 ms 186 ms wargaming-ic-305210-snge-b1.c.telia.net [62.115.38.218] 18 187 ms 186 ms 188 ms wotsg1-slave-37.worldoftanks.sg [92.223.16.37]
Trace complete.
C:UsersMom>
======================================================================================================================== I am also facing manual login issues from past 3 days , did not have this issue in first 2 weeks, have dropped them an email to fix this, as manual login is a pain. Also does anyone know how to login and check the stats of the cable modem provided.
The model no is CM 4100 and it says manufactured by Shenzen . There is no manufacturer name on it as hathway have put their logo on it.
Found these details on Googling :
http://www.marketwatch.com/story/maxlinear-mxl261-multi-channel-tuner-demodulator-powers-docsis-30-products-from-skyworth-2014-04-14
http://www.maxlinear.com/maxlinear-mxl261-multi-channel-tuner-demodulator-powers-docsis-3-0-products-from-skyworth/
Its made by skyworth.
The CM4100, first in Skyworth’s new DOCSIS 3.0 family, is a high-speed data cable modem designed using both the MxL261 and the Intel® Puma™ 5 chipset. Providing up to 200 Mbps data speeds, the CM4100 serves as a broadband network controller for residential and small-office applications.
Dushie said:
Here you go ...
Traceroute :
Trace complete.
C:UsersMom>
The model no is CM 4100 and it says manufactured by Shenzen . There is no manufacturer make on it.
Thanks mate :)
