Are you sure the Huawei K4505 is 28.8 mbps.I've search everywhere and the information I get is its only 21 mbps.
The firmware soft on the current device suports 21mbps and the device board supports 28mbps.
If you update the latest firmware soft you will get 28mbps
the same in the case of upload speed of E1752 it upload speed is 2mbps, if you update its firmware soft it will get 5mbps.
---------- Post added at 02:53 PM ---------- Previous post was at 02:38 PM ----------
It does get seriously hot.
And since its chilled winter here, and fingers get freezed, i used the modem to heat up my fingers.
thats funny my friend. haa haaa
Is there any disconnection?
