Yes sir, tried everything still it shows dynamic "abts-north-dynamic" by the way after this in ip MY STATIC IP IS NOT LISTED, INSTEAD OF THIS SOME OTHER IP IS LISTED"abts-north-dynamic-204.XXX.XXX.X22.airtelbroadband.in"
raise immediate complaint. and get your refund (if you're paying any charges.)
EDIT: Also ask them what is your exact IP on static IP and then match with ip you're getting on ipinfo.io
IF its not same, first fix it and then raise complaint for static ip refund as you never received this service.
Nono, I Applied for Static ip but for some reasons it was not allotted, then again after contacting them it was applied by the backend team although at that time my ont was not in bridge mode.... Still I haven't got the Ip bill......what to do? should i switch isp?
Changing ISP is your decision.
So you're saying, when backend team applied static IP, your connection was not in bridge mode and now you're using bridge mode.
So ask Airtel again, setup your static ip in bridge mode.
if my ont is in bridge mode then where will the backend set the static Ip??I have configured my gigabyte mi 4a router with static ip which was previously there in my ont....
