  • Replies Replies 230
  • Views Views 26,078
Tejas01
Dream big in life.
Mumbai
Airtel XStream Fiber
7. Budget 15,000-18,000.
I will try to answer point wise
2) 6.5kg (ideal) or 7 should be just enough. You will always find something to wash in it. What I don't do is wash my shoes in it. Believe it or not some people actually do that in the same washing machine.
3) LG ( thought last one was a big disappointment) or Samsung is good in Mumbai. I would have opted for one of these but when we went in for a new one in the beginning of this year we got a shock that in top loading they dont make machines with option for hot & cold water. Our entire plumbing in our house is ithe provision foe hot & cold inlets for the machine. So we bought an IFB which had this provision.
4) & 5) Parts should not be a problem for LG & Samsung in Mumbai.
6) This should not be a problem either, there should not be any problem in water pressure. I have only one floor above me & then terrace with the water tanks, I never had any problems.
7) Should fit you budget.
8) Answered above.
Any stand will increase vibration & hence noise. Where would you want to move it again in your house. I didn't understand this point.🤔. Just ensure that the machine is on level ground. Many machines have a built level meter or you can use a spirit level to check the same. Usually the demo guy checks this for you & does the needful. Like putting some padding if necessary just like wth refrigerators & cupboards. 😁
Thanks for your detailed reply..
Sorry for not being clear in the earlier post. I initially thought of moving the m/c from the kitchen through the hall to 1st bathroom which has an additional tank. So in summers when there is sureshot cut in supply from BMC, I thought of running the machine from the tank instead of direct supply, but that would be really cumbersome. Also, if there are some wheels you can clean the area occupied. Kitchen is entire marble so I am sure it will leave permanent stains if not cleaned regularly. How do you manage with cleaning?
Can you share your experience with top load m/c wrt its cleaning ability, power consumption and maintenance. Many people on this forum in other threads and this have suggested to go for Front load given its advantages over power,water and cleaning ability. While I could get try to get FL m/c, space could be a constraint. I really need to use the measuring tape to estimate the space taken by the FL m/c.
Also with IFB, many suggested not to go due to its poor after sales support.
We have separate niche for the washing machine. It was made taking into account the then machine in use plus a few inches on all side with ample space to open the top. I can sneak the vacuum cleaner tube at the bottom to remove dust or remove the entire machine to clean that space. We have had tvs whirlpool, Samsung & LG & now IFB. All top loading as theres a fear of water stopping when machine is in use & clothes getting stuck in the machine. Incase of top loading can remove clothes & wash by hand using an alternate sources of water. The machine is outside the bathroom (with a power socket next to it) so water splashing, the inlet & outlet pipes are led thru holes in the wall to the bathroom.
Never used front loading so far but they should be better as they work at a higher rpm. Especially the direct drive ones.
Are their drums sealed permanently like in Bosch, Siemens or they have modular arrangement wherein you can replace the drum in case if there is any fault and
Also, how is their heating mechanism?
I do not have a in-depth idea about the modular arrangement , but in LG it is called Direct drive motor mechansim . It means the drive motor connects directly to the drum . This reduces vibration and energy loss as I know .
LG has built-in heating . Takes cold water inlet(single inlet for water) , heats the water( you have option for temperature setting)
@shashankb Thanks for that... I was aware of DD being a brushless motor leading to less vibrations and low power consumption.
What I meant was companies like Bosch, Siemens, Whirlpool use sealed drums. So in case if any part to ensure the working of the drum goes bad, you have to replace the entire assembly instead of the the faulty component. This becomes problemtic post warranty as replacing a faulty part is much cheaper than replacing the entire assembly(almost like getting a new machine). There were also lawsuits filed against the first two companies in EU for such malpractices and they had to revert back to older arrangement. Sorry, if my use of wordings caused confusion.
LG does not use sealed drums as per my knowledge, but not sure hence I asked here.
I would have posted links from other forum here but I think it's against rules. :)
@socrates Does you machine has the provision to limit the rpm of the drum as in FL. That way it could help to reduce the wear and tear of the drum by running at lesser rpm.
