I actually don't even have a slightest clue on how an ISP's backend works, so pardon my incomplete knowledge first =)
As per my findings, BSNL distributes their traffic (at least in my area) via 5 different local gateways. Each of those gateway connect to VSNL Chennai for certain routes while others go another way (like, via POL for instance) and for me to get a different local gateway, I'd need to disconnect and reconnect my connection. It works most of the times, but to get a magical gateway (read, the one with low usage) - it takes me an hour at least. It has the best pings BSNL has to offer, for the entire world.
For example, here's a traceroute to
Google I took this morning with the local gateway 117.201.112.1 :
Now, you can compare the same, with the current gateway I'm connected to (117.216.8.1)
I specifically tried to connect to the gateway of my choice, but BSNL doesn't allow that since its only allocated randomly by their server.
Thank god, at least someone is aware of this! Thanks for an update
Any idea when it'll be back to normal?
Oh right, I misunderstood - I thought you'd managed to get yourself assigned to a particular one on purpose rather than by trial and error.
Yes, having multiple gateway servers is both good and necessary, but if you're not being connected to the lowest usage one automatically, this suggests something is askew with their setup and the RAS server isn't balancing the load properly and for some reason it's ignoring the gateway which doesn't have very high utilization for reasons unknown - this could be anything from a simple misconfiguration (priority=10 instead of priority=100 or something) to something completely random, stupid or simple - even a funky ethernet cable or switch somewhere - as the post about the faulty switch seems to suggest.
But without knowing more intimate details about BSNL, it's anybody's guess except the NOC team.
