I have a perfectly working MTNL Triband connection with the same Netgear Router that you have.
InternetD-Link 502T(10.10.30.1)(10.10.30.2)Netgear WGR614(192.168.5.1)PC through LAN & Laptop through WiFi. My PPPoE dialing happens through Netgear & it also acts as the DHCP Server.
well, lucky you!
i tried everything but in vain!
As already pointed by someone else, the ipconfig output shows a different DNS Server than the one you have set manually in the TCP/IP settings of your LAN card.
thats coz i took images at different times. now it is all set to obtain automatically.. still wont help!
finally, i have managed a workaround as of now...
i disabled the DHCP server in netgear and have assigned ip to my pc and laptop. also connected bsnl modem to one of the switch ports (earlier it was con to the main WAN port, beside the antenna). basically made it into just an access point.
so, now, control is back to bsnl modem. it acts as default gateway instead of the router. but few problems:
Now i have to connect manually to net i.e. as it was before.. dial the pppoe connection manually. netgear wont auto connect as bsnl modem is now conn to switch port. this means i cant share my net connection across my pc and lap simultaneously... only 1 can access at a time! :wall:
that also means that my n95 cant connect to dataone over wifi as it cant basically dial a pppoe connection!
please help me get everything back to normal!!! i want the netgear to be the dhcp server, it should dial automatically and allow simultaneous net access to all my devices! how do i do that? no solution elsewhere on the net too!
well, lucky you!
