Setting up WRG614 wifi router with bsnl broadband?
  • Thread starter Thread starter JiGGz
  • Replies Replies 30
  • Views Views 16,691
Answer to the first quoted msg :
I said, connect Router to PC. not to bsnl modem !
Connect PC to 1-4 ports of Router ! (what i meant by pc is your system, personal computer) !
Answer Second Quoted Msg:
You are not supposed to connect both Modem and Router before configuring fully. because you cant get things right ! So dont connect bsnl modem for that time being!
Answer to Third Quote
If you dont see that, Just give primary dns as 192.168.1.1 and secondary dns as one of the DNS (either opendns or bsnl dns) ! (wont hurt since you have it in modem !)
By the way, dont you have given details of your username/password in BSNL modem ? then why you again giving in basic setup page in Router (seen above pic)?
You just dont have to connect all that ! That is only when you bridge the modem and router. ie, If You remove all settings from modem and enable bridge mode over there, and give those connection details in Router. As of now that is not required !
If you havent changed anything on bsnl modem, please keep Router as simple (Click No on 'Does your internet require a login' on Router)
