Slow Speed and High Ping Problems on Reliance Jio Fiber Broadband
Steam Download Speed 100 Mbps Plan.
Games, TeamSpeak, Other Applications who are dependent upon Ping and many websites.
One thing more I wanted to say, because of this high latency. I face a lot of PACKET LOSS at the multiple hops....(LAN hops and next 2-3 jio hops don't have packet loss)
Edit: 2 AM
Everything is now working fine (as I said above, ping and speeds are fine after mid-night.... till late morning around 11 am or something)
High Ping issue is still not resolved. Facing since March, 2020.
Ping gets normal only after mid-night. Like around 2AM or 3AM.
Ping again gets high in the late morning (as people wake up).
Talking with Customer Support, Nodal, Area Head, Area Engineers did not help me at all. According to them, everything is fine.
Delhi to Singapore:
(At night: 70-80ms)
Delhi to ACT (Delhi):
(At night: 4ms)
Delhi to Paris, France:
(At night: 140-150ms)
Everything is tested on Ethernet/LAN.
Any Solution?
this is jio noida ip which i am tracing via. jiofiber broadband.
you can see how bad routing is that jio delhi is having poorest ping to jio noida (which used to be 3-4ms before all these issue)
now this also gets normal to 4ms daily at mid-night after 1-2 am and goes back to shit in late morning.
don't mind but i see only myself having this issue.. i seriously didn't find any second person from delhi having the same issue on this forum... you know anyone else? you can tag.
also can you tell me technically.. what's the reason for this issue?
It's most likely network congestion, I used to have the same latency issues on my old provider. Otherwise it could be poor maintenance by the people in charge. Eitherways, you can look around the forum I've seen many people here and even on reddit complain and whenever I ask its almost always Delhi NCR.
i used to face same issue on hathway in 2018...
anyways, so there is nothing we can do about it except for either living with it or find alternative?
also, i wish if someone could share the setup process of wireguard on aws?
i wish to give that a try.
