dont all olts support g7? @Rickysin
Yes @rajat_ have about 18 IOT devices , 16 IP cameras + always 30-35 clients on Decomesh but never faced problem on a 300 mbps connection, it just depends on your hardware .
Also has anyone idea how to configure SFP SC with airtel???
Forget Ookla or any other speedtest application. Are you getting full speeds while downloading games or torrents? If yes, there's nothing to worry about.
tplink ont is just working in bridge mode and has no other features at all.
nokia on other hand is having full fledged features like pppoe or dynamic or static link connection. NAT, routing, voip, ip assignments, dmz, and other load of things.
so nokia ont will be using high cpu and memory resources resulting in lower performance than tplink ont
so using own good router with media converter ONU is wiser choice.
@Rickysin i Definitely agree its a wiser choice, but practically does it solve the issue mentioned by op for ont limiting the acheivable wifi speed from the router used?
In my case sercom ont wifi speed>>> sercom ont bridged+TP-Linkc6 v4
see @droidrex I also use the same setup as @Rickysin and I can see the speeds and ping are very constant now compared to my previous Nokiaont. When using nokia it used to get hot the speed fluctuated a lot even though it was in bridge mode.
It is definitely a wiser choice to remove airtel ont and use your own if you want to use what you paid for .\
But at last most people will never notice these fluctuations, It all depends at last what do you want.
Also it saves a lot of space if it is a premium for you.
there are cases where some airtel ONTs exhibit variable frequency on ethernet ports of the router, so even if its in bridge mode , the LAN port might be having low frequency hence speed fluctuation is there.
there is a rare chance that your local OLT is saturated but again this is very rare to none in airtel case.
