How good is the connectivity? I do minimal downloading so I don't need a big download cap. I absolutely require a connection that does not break down.
I am in the Adyar area.
Would e great if someone could answer.
Hello,
Thanks for showing interest in ACT Broadband. Kindly share your complete postal address and contact number with us so that our team can get in touch with you after checking the feasibility of our services in your area.
Warm Regards,
ACT Broadband
Am currently using BSNL . I am planning to switch to ACT in Velachery. I have a few questions to the ACT Users :
1. Is the connection reliable? BSNL has outages as well. I can do fine if it does not happen often.
2. Are speeds relatively decent ? Obviously you can't get the promised speed - But atleast 70%?
3. Is having the Box in your place an advantage in any way ?
4. Suggest some Routers that work with ACT - that would work with other ISP as well. Budget - 1k.
@uberjon - I would appreciate your Inputs as well
1. More reliable than BSNL. Less than Airtel.
2. Speed - More than 70% promised speed.
3. Response time is slow, but it's a little faster if you have the box on your premises, as it affects all users connected to that box. So, you get a higher priority + Rs. 45 discount on your monthly bill.
4. ANY proper WAN router will work.
@uberjon Thanks a lot I have narrowed down on two Routers and would be great if you could confirm if they work with ACT . And also the better one if you can
