QUOTE(gavnitsingh @ Jul 27 2006, 11:06 PM) [snapback]56887[/snapback]
Lol! How much is transfer rate between two drives in your hard disk ?
I think it is not more than 100Mbits/sec. Or could be about 300Mb/sec in dual core processor which i don't have.
So what be required to use this theoretical speed 2.5Gbits/sec?? Only a theoritical Super omputer will work. LOL
[/b]
err..no
on my p3 700 (a 5 yr old computer !) which has UDMA-4 or 66MB/s that would be 528Mb/s (theoretical)..
Using
HD Tune my pc shows an avg of 46.6MB/s or 373kb/s. i sugggest you try that app out and you might be quite happy to find that transfer rate on your two drives is maybe 3+(?) times what you think. Dual core processor...lol.. got nothing to do with it whatsoever...
And that's pretty much sustained, you would see half that on USB2 for big (ie long) transfers.
Nowadays the fastest on PATA Is UDMA-6 or 133MB/s with SATA-1 its 150MB/s & SATA-2 its 300MB/s (2Gb/s+)
Of course that was a slight digression from the incredible speeds these lucky French dudes get to have. Don't forget speed to outside that tiny segment is likely to be 1000 times slower...so not much fun if all the good stuff is outside, which it most likely is.
