Can't do much about locked devices. My device is 2.5 Ghz too. I get 60mbps on speedtest.net app. Try changing the Wifi security settings and see if that helps.
@SuperK can't you unplug the fiber cable and disable the remote management things on the ont if you know the password. It's LOID I think, maybe @sloj can confirm.
The GM just said that I can buy a 2 in 1 ONU and router from a branded company but it won't be compatible with their system. So, I have to use this local ONU and then I can add a branded AC router to get project higher wifi speeds. What do you all think? Should I do that?
Find here the complete list of Fiber ONT or ONU compatible with BSNL Bharat Fibre service provided by BSNL TIPs (Telecom Infrastructure Providers), which are
It comes down to if the service is EPON or GPON. Most locally available ones are XPON so it supports both. So it shouldn't matter unless they maintain a whitelist of devices on OLT or there is compatibility issue.
You can get a simple device with just a gigabit port but then what about phone service.
