Facing problems while upgrading to 1Gbps plan
  • Thread starter Thread starter havoc
  • Replies Replies 14
  • Views Views 1,492
havoc
I got banned!
India
Excitel, Vi, Airtel, Jio & BSNL 😉
As previous threads were going offtopic I decided to talk about it here. (TBH moderation staff issued a warning that's why 😅)
So guys what's the problem with upgrading to 1Gig? Do they have to change ports or do some configurations to OLT? As @Chip mentioned he always faces issues while upgrading to 300+ plans. What's exactly the issue with 1 Gbps upgrade?
Maybe a change of the OLT and routing. They changed me over to a new gateway for static IP. The Nokia ONT can handle 1 gig. I don't want the fugly Dasan or Sercomm.
I suspect that the Airtel field staff get complaints from customers who want 1g plan but unbeknownst to them their wifi router and/or clients like mobile and laptop don't support 1g speeds so they yell lol.
I guess only rare cases like us we know about this and self ensure we have supported wifi and Ethernet links and we have to take extra steps to inform the staff that they don't need to do a feasibility check or replace router etc.
The person I spoke to on Monday confirmed there would be no need to change the ONT as it supports 1 gig. What happens after the ONT is not their issue. They haven't even changed the billing plan! :D Today I heard a different story which gives rise to the WTF kind of feeling.
TPBB washed their hands off it last year. It gave 1 gig only when connected to THEIR laptop and THEIR cable. While my considerably more powerful Core i7 extreme desktop machine (since upgraded) managed 500 Megs. Now, I can put it down to the NIC/LAN card but it's a Broadcom + Intel not some pappu Realtek etc.
So the plan has been activated..tech came over and had to do some changes via their 'zero touch' system. The idiots changed the SSID wifi password and I am unable to change it now via the Airtel app. About speed any issues and he said he'll have the NOC make changes. Lets see.
So youre not able to browse internet? Try Airtel@123 as password.
For me on Tata Play Fiber, upgrading to 500Mbps and 1Gbps requires special configuration which only higher ups have access to change. I don’t know if they physically changed OLTs or ports.
@tatyasky it's something like that with Airtel too. But they have faster turnaround times. With TP, it was seamless...no fuss last year. Best part? The festival discount which IIRC you had shared on the forum. In contrast Airtel has its head stuck in its rear end.
@nishantt6969 - Nopes didn't work. But thanks anyways. I'll have to call their CC tomm.
Do you have any antivirus software or 3rd party firewall installed on your machine?
Is it Windows or Linux machine?
I used to have a similar issue. That was because of Bitdefender throttling the network speed on Windows (400-500Mbps). Also even on clean windows, the speed was (around 700-800Mbps) lower than on Linux(Ubuntu) (900+Mbps). Maybe some driver issue.
@imdarkray Yes AV is on by default currently using Bitdefender or Kaspersky (I alternate between them very few months)...the AV shouldn't be throttling it. It behaves the same with or with out these apps. It's a Broadcom though an old one so shouldn't be so bad. It works full tilt on LAN transfers (115-120 MBps) though so it can't be to blame. It has the latest W11 drivers too.
