@Dushie, @ghpk
Flashing K4505 modem with K4505 update and UMG1831 with 1831 update makes nothing wrong.
K4505 modem behaves smoothly after update, since it is written specifically for K4505. Yes K4505 modem is also originally manufactured as 21.6 Mbps card. Only updating with K4505 specific files, it is upgraded to 28.8Mbps.
But flashing UMG 1831 with K4505 update is subject to owner's risk.Some plus some minus.
Normally any update SW will check the compatibility of the device and SW, before installation, and will exhibit warning or refuse to install. Here nothing happened. Is it the bug in the update SW ?
umg 1831 alredy supported 21.6 mpbs with all firmware
not need unbranded firmware like k4505,e182e
k4505,e182e and all 21 mpbs firmwares match to umg 1831
am get 1000kpbs DL in my 7.2 mpbs modem with download manager!!! its magic
1000kbps = 0.98Mbps
So getting a speed of 0.98Mbps with 7.2Mbps card, what is the magic ?
