  • Replies Replies 230
  • Views Views 26,078
Tejas01
Dream big in life.
Mumbai
Airtel XStream Fiber
7. Budget 15,000-18,000.
@Sushubh and other who have LG machine fl. Does your machine vibrate when the machine is in spin cycle? Mine vibrates a bit more than what I see as satisfactory.
Also mine starts tilting from right to left when I try to rinse a single T-shirt. Does this mean a single cloth item is an absolute no-go for these machines? I did level the machine and remove the transit bolts, but issue still exists.
I am more concerned with tilting while washing a single cloth than the machine vibrating.
Well that should not happen . Mine stays put like a giant rock
Does your machine lift off the ground literally while rotating on one side ?
@shashankb even while using a single cloth item?? I agree that when there is less than the required load the machine will start walking during spin cycle but a t-shirt even after getting soaked shouldn't move the machine as it's weight is far less. The LG guys tell me that machine vibrations is normal and you should expect this much vibrations and shaking.
Which model are you having?
LG Directdrive 5.5Kg F8068LDP . I put a single mini blanket in the machine and it worked fine last time . It is just 5.5Kg so the drum is not that big . You know the inertia increases as the radius of drum increases
In simple words , a big drum causes a lot of shaking
