@_@... it still isn't working
I've set it to GSM and all other options are the same. Restarted the Phone. Sent SMS. FAIL -_-;
---------- Post added at 02:03 PM ---------- Previous post was at 01:59 PM ----------
p.s- I still keep on getting RANDOM sending messages... -___-" and still no luck with GPRS either
Help!!
always.. after making the settings,, power OFF and wait for some minutes of time. and ON the mobile,, then check things.. because.. the server from telecom should also update.. your settings.. to that side..
---------- Post added at 02:22 PM ---------- Previous post was at 02:19 PM ----------
regarding gprs have you set gprs settings to
TATA DOCOMO INTERNET or TATADOCOMO DIVE IN
---------- Post added at 02:11 PM ---------- Previous post was at 02:08 PM ----------
regarding sms try putting docomo sim in another phone
dive in usage is if u have not gone for any pack of rs 15- Rs95 with docomo.. and u want to use internet .. then use dive in..
other wise.. tata docomo internet for using with recharges of mobile internet with Rs15- Rs48 - Rs 95
