[INFO] pppd[1089]: CHAP authentication succeeded: CHAP authentication success
#00358 2022-04-22T21:25:29+0530 [NOTE] pppd[1089]: CHAP authentication succeeded
#00359 2022-04-22T21:25:29+0530 [NOTE] pppd[1089]: peer from calling number 02:00:5E:XXXX authorized
#00360 2022-04-22T21:25:29+0530 [NOTE] pppd[1089]: local IP address 117.197.XXXXXX
#00361 2022-04-22T21:25:29+0530 [NOTE] pppd[1089]: remote IP address 117.197.XXXXX
#00362 2022-04-22T21:25:29+0530
00379 2022-04-22T21:26:00+0530 [NOTE] AUTH[848]: Attempt to proceed a RPC with invalid token: INVALID_TOKEN
#00380 2022-04-22T21:26:00+0530 [NOTE] AUTH[848]: Attempt to proceed a RPC with invalid token: INVALID_TOKEN
#00381 2022-04-22T21:26:00+0530 [NOTE] AUTH[848]: Attempt to proceed a RPC with invalid token: INVALID_TOKEN
#00382 2022-04-22T21:26:00+0530 [NOTE] AUTH[848]: Attempt to proceed a RPC with invalid token: INVALID_TOKEN
#00510 2024-06-09T21:41:51+0530 [WARN] kernel: [wlan0]: A STA is expired - b624f1
These are fine, that AUTH error is not related to pppd. I'm on 117.251.xxxx and I'm facing the same issues you are. Really bad routing, sites slowing down to completely failing.
@Gaurav_G The issue is beyond LCO level. Ask LCO escalate the matter to BSNL since you aren't getting proper speed. If LCO still keeps repeating the same thing then complaint on PGRMS portal.
Even i am facing packet loss multiple times in a day for the past 2 months. Looking at ripe probes in my state on bsnl, all have same spikes of packet loss. The strange part is that bsnl officials are not even aware of any such issue.
