^^^ well what I intended to say was not a practical approach, just to show that with the current pricing its very much possible to get 2Mbps UL at approx. 1500 Frankly just a way to be over-anxious of a new price cut
Well what can we say, the BSNL guys are such jokers!!!Why would anyone pay double the price for a plan which will revert back to 750/- within a day????I think BSNL guys got their maths wrong or they are illiterate.. who knows...
My UL1350 has finally got upgraded this morning. https://www.speedtest.net My line has been connected to the NIB II network. By the way how does one check the usage on this NIB II network. I was told to go to BSNL Portal log on and check the usage there but I cannot find any link there to check the usage. The only options I have are View Your Profile, Change Your Portal User ID, Change Your Portal Password and Track Your Portal Order. The old place where I used to check does not work anymore
I think that there wont be any fair usage policy in 750ul plan because they have increased speed of 1350ul plan and implemented fair usage as well. So, if they wanted they could have introduced fair usage in 750 plan along with speed increase. What do you say folks ???
Knowing BSNL there hasn't been any FUP in the 256KBps plans. Since they have been automatically upgraded to 512KBPs without any intervention from the user's end, there won't be an Fair Usage Policy on the 750 UL plans.The 1350 UL fellows are getting a really raw deal with a 2mbps speed burst upto 15Gb. I predict most users might switch over to the lower 750 plans simply because the 1350 plan doesn't make any sense if one is not using the 250 free calls they allow on it.
