So after much deliberations and consultations, finally came to this conclusion/plan.
I will be placing
A6/
C6 on the wall adjoining room 2 which will be in the central location and also it gives the best signal of 49-50db(room 3 door open and around 57-60db with door closed) from my main
router. It will be setup using WDS.
From A6/C6, will lay the ethernet wire tucked along the marble frame so that it won't be easily visible upto the
TV.
I would have gone for
Deco mesh as mentioned by igloo but I don't think they could be hunged, or even if they are hunged it is easily noticeable to raise eyebrows. I just hope the difference in speeds between mesh and the router is less.
Another point, Will I be able to use wifi from A6/C6? Also, how should I configure A6/C6?
Any other point if I have missed?
Also while A6 comes with v3 out of the box, C6 has
firmware upgrade stuck to v2. So don't know if support will be available for openwrt.
