Sun direct HD dth with NTSC TV?
  • Thread starter Thread starter mac9999
  • Replies Replies 32
  • Views Views 33,151
Glad to know that NTSC TV problem is finally solved with this SUN STB. I would like to know if similar NTSC STB is available with HDMI as well. I will wait until then
I tried my Sony w5100 series NTSC (US) tv ( 110/220v,50Hz/60Hz support) with the sundirect HD stb samsung,connected thru HDMI cable, but it does not work out. TV displays as "Unsupported signal. please check the device output". I tried changing the samsung STB resolution (connected thru videocable connection) to different available resolutions like 720p or 1080i, but nothing seems workedout.my tv supported video formats: 1080p/60,1080i/60, 1080p/24 (HDMI only), 720i/p/60I think the only option for me now is, to go for either ATLONA box or DVDO EDGE. Anyone succeeded with the samsung stb sundirect HD here? pls. share your inputs.
Sundirect Provides Coship company's STB . It works well with NTSC Tv's
I guess with coship you can only get standard def from SUN DTH but not SUN HD DTH, how is the SD quality?
We also faced this issue. When we connected our TV, the picture displayed only in Black and White without audio. Luckily the local cable operator brought a "Digital Cable Receiver" AC-2510 Plus from "Seans Media Private Limited" which had options to select between NTSC/PAL as the output format. It's cost was around Rs.1,000 /-. Once we selected the right output format it started working amazingly well.
This worked out to be a really cheap and quality solution and available locally in the Indian Market.
hi ,i just got a Sony kdl-40 hx 800 tv from usa ...did nt know about the ntsc ,pal difference....i am right now using reliance big tv stb [basic and not hd]. i connected that with my tv using av output...but to my utter surprise i can only see b/w images.....cAN somebody pls help me out??..i feel so stupid by buying this tv .....saw a hundred posts , with some one supporting that sun hd or dish hd will work and some contradicitng that...can somebody pls help me out.....thanks.....
yes, that is true,.. but us made tv sets only have palm system..so my query is if hd set top box in india has the facility of running on this ntsc television ....??
anyone.. who is succesfully using us lcd `s in india , pls help me out..i feel lie totally crippled without my tv..... mr kama , can u pls provide some more information on what tv u r using and what stb settigs u used??/ if possible can u pls ggive u r emaill id ???
